differential equations - solve differential equations - Сообщения
If you can please explain the various steps to be able to solve the differential equation in the picture.
I am interested in deriving the function phi (t), what do you need to know to solve the differential equation?
Thanks for your patience
Documento2 DE [explain more] (25).sm (48,29 КиБ) скачан 1176 раз(а).
Wrotesorry but I have practically no experience with this program and I find it difficult to understand the functions.
T
The setup to numerical DE solver is same as Mathcad,
even superior as it takes the parameters as vector.
Use p[1,2,3] for those parameters.
Up to what you proposed before: you don't have a DE
Those parameters are non-sense as they send the system in the zillion domain. Get that DE from the teacher, a bit of abstract would help.
Documento2 DE [explain more] (25).sm (71,7 КиБ) скачан 1156 раз(а).
Wrote...
Hi. Usually we want know the ode and it's initial conditions. In your case you have boundary conditions, which can be solved by the shooting method.
Hope this helps.
motocicleta.sm (48,71 КиБ) скачан 1339 раз(а).
motocicleta.pdf (203,43 КиБ) скачан 864 раз(а).
-phi(t = 0) = 0.146
-phi'(t = 0) = 0
WroteMy initial conditions are:
-phi(t = 0) = 0.146
-phi'(t = 0) = 0
For a Cauchy problem it's more easy.
motocicleta with IC.sm (37,14 КиБ) скачан 1328 раз(а).
motocicleta with IC.pdf (136,74 КиБ) скачан 875 раз(а).
regards
1. What maths are given/invented: a formula ?
2. From that formula, what is next
So, you have a formula and an objective project,
i.e: a pretty short work sheet not yet circular in the blue.
WroteThis is an offer ... accept/reject ... go back to "square zero"
I appreciate the advice. I'm trying to learn
WroteI appreciate the advice. I'm trying to learn
Just give the formula that you were given.
or make an image from source ... learning is after.
These two examples are Cauchy integration. They have no formal symbolic.
A discrete integration is possible via the module rkf4(y0,x0,x1,n,f).
From there: easy to get the discrete derivative.
ODE Cauchy Project.sm (27,38 КиБ) скачан 1367 раз(а).
I tried using Simpson and Romberg's recursive methods, but without getting a solution.
Where am I wrong?
PROJECT.sm (69,12 КиБ) скачан 1383 раз(а).
WroteHi, sorry if I bother you again. I'm trying to integrate a function, the function in question is psi''(t) in order to derive psi'(t).
You have phi in your document ... psi is a built-in function.
So, if phi''(t) is the 2nd derivative ... then the derivative
is simply the integral. To expedite fast: done discrete.
If you have questions: please re-post this document.
PROJECT [1].sm (30,82 КиБ) скачан 1139 раз(а).
WroteYou have phi in your document
.... in fact you have PSI''(t).
Maple does not find an explicit integral.
PROJECT [1].sm (21,91 КиБ) скачан 1152 раз(а).
Where am I wrong?
Hi. You can use any Runge Kutta solver for integration.
Also, you can use SMath int procedure, but it's very (very) slow:
For the theory, remember that you can integrate (with definite integrals) both sides of an equation and get an equality too, which don't work with derivatives.
PROJECT.sm (74,9 КиБ) скачан 1393 раз(а).
But now I can't calculate the ratio in the picture.
The error says, "The matrix must be square"
PROJECT.sm (57,24 КиБ) скачан 1377 раз(а).
WroteHi, I have calculated the function psi '(t) through dn_GearsBDF.
Result from numerical ODE solvers is a data set.
Generate an interpolation scalar to 'x' ... then plot.
@ the end of the document ... more questions: -this one.
PROJECT (1).sm (74,9 КиБ) скачан 1372 раз(а).
