Make Up Water Requirement using CoolProp Enthalpy Balance
Make Up Water Requirement using CoolProp Enthalpy Balance - Сообщения
#1 Опубликовано: 19.02.2023 15:03:43
usamakhan
usamakhan
6 сообщений из 93 понравились пользователям.
In my plant 20 pumps require flush water which is supplied by a close circuit water flow network. Flush rate & max temperature rise are per vendor specifications. Hot purge & simultaneous volume makeup by fresh water is what maintains the temperature.
I am attaching my solution to the problem. I further need to have multiple plots (on same graph) which corresponds to different temperature rises indicated by equation defining Tc. Please advice
FlushWater_updatedCoolProp2.sm (82,93 КиБ) скачан 1297 раз(а).
#2 Опубликовано: 20.02.2023 03:48:32
Hi. Maybe, something like this?
FlushWater_updatedCoolProp2.sm (92,32 КиБ) скачан 1325 раз(а).
#3 Опубликовано: 20.02.2023 13:58:31
usamakhan
usamakhan
This should have worked ...the data dimensions are correct
#4 Опубликовано: 20.02.2023 14:13:36
#5 Опубликовано: 20.02.2023 19:24:07
usamakhan
usamakhan
I am waiting for a heat exchanger (with temperature loop) which will take x3 months. In the meantime I want to use make up water for temperature control by hot bleeding. Bleeded stream will not be wasted & goes to Cooling Tower makeup ...
Jean, can we use solve() command somehow?
#6 Опубликовано: 20.02.2023 19:48:43
Better wait the heat exchanger c/w control loop.
Detail: most likely the control algorithm will be Lead/Lag.
Your document is red. I will revisit.
In my native SS 6179, if CoolProp is used in another document
it can be called from another document ... a damned bug.
#7 Опубликовано: 20.02.2023 20:49:41
No luck, your document is red with 1 page long error message.
You are trying to plot something, tabulate the data set.
From there, no problem to fit/solve.
#8 Опубликовано: 21.02.2023 10:41:28
Revisit the heat exchanger LMTD.
Inst_LMTD.sm (32,13 КиБ) скачан 1331 раз(а).
#9 Опубликовано: 21.02.2023 13:56:08
usamakhan
usamakhan
Mr. Jean thanks for your input but we will be using Plate & Frame heat exchnagers which design is very differnt from tubular exchangers.
Now I have x2 matrices (ranges) changing TB (5 values) which plot a curve at changing TC (3 values) ...so we have x3 curves. Can you change attached file to my requirement
FlushWater_updatedCoolProp3.sm (89,35 КиБ) скачан 1260 раз(а).
#10 Опубликовано: 21.02.2023 18:33:53
Sorry Collab, your document is red in native SS 6179.
My understanding follows.
FlushWater_updatedCoolProp3.sm (98,45 КиБ) скачан 1302 раз(а).
#11 Опубликовано: 22.02.2023 07:53:15
usamakhan
usamakhan
Jean, because CoolProp addin is not installed (I am also using secant() from nonlinear addin) thats why its throwing error. Check the pdf. Any recommendations from your side
Flush Water.pdf (359,31 КиБ) скачан 802 раз(а).
#12 Опубликовано: 22.02.2023 09:47:26
Nice PDF ... can you make it an Smath document for checking.
CoolProp is an old vintage. Mike helped a lot, as well Alvaro.
I don't use ... rather WASP from Mathcad 11 coded Smath.
By same token, Katmar WASP is freeware for 5 minutes per use.
Once you have your [°C ... kJ/kg] data, you can resume the project.
Most interesting ,,, Cheers ... Jean.
FlushWater_updatedCoolProp3 RESUMED Version.sm (9,8 КиБ) скачан 1347 раз(а).
#13 Опубликовано: 22.02.2023 12:24:05
usamakhan
usamakhan
Jean, Thnaks for your plot() function. Here is the .sm file. Being a chemical engineer I cannot let go of CoolProp bcz besides water I have to deal with many gases like N2, air, Cl2, CO2 ...so its vital for me. Additionally, I have seen here that Prode Properties is being used as an Smath addin I will certainly try to make it work bcz I have already integrated it in Excel
FlushWater_final_old.sm (96,83 КиБ) скачан 1270 раз(а).
#14 Опубликовано: 23.02.2023 11:38:03
For convenience, I have added bilinear interpolation.
FlushWater_updatedCoolProp3 RESUMED Version.sm (21,45 КиБ) скачан 1358 раз(а).
