[SS-4637] Error opening file
[SS-4637] Error opening file - messed up worksheet code - Сообщения
#1 Опубликовано: 14.04.2020 10:11:37
Даниил Вячеславович 416
0 сообщений из 10 понравились пользователям.
При открытии файла появляется окно ошибки:
"Данные на корневом уровне недействительны. Строка 1, позиция 1."
Версия: 0.99 (сборка 6839)
Прикрепляю файл:
Raschety po ehkonomike.sm (68,25 КиБ) скачан 1489 раз(а).
Пожалуйста, ответьте, я работал с этим файлом очень долго ;(
Если возможно восстановить хотя бы часть данных, буду очень благодарен
#2 Опубликовано: 14.04.2020 11:00:26
It's a pretty strange kind of damage, never seen before by me.
The file starts with a sort of *.ini data content, then there is what seems a chunk of a *.pptx archive and finally the worksheet tail. o_o
Unfortunately there seems to be only a small part of your original worksheet still there.
Raschety po ehkonomike_recover.sm (5,42 КиБ) скачан 1451 раз(а).
Даниил Вячеславович 416 14.04.2020 11:23:00, Andrey Ivashov 14.04.2020 17:40:00
#3 Опубликовано: 14.04.2020 11:03:25
Last file save was made with SMath Studio 0.99.6839 ? (if you are able to remember it)
#4 Опубликовано: 14.04.2020 11:15:31
Maybe I was wrong, And used the 0.99.6839 version
#5 Опубликовано: 14.04.2020 11:37:38
Some lines were stained orange.
Does this relate to my problem?
#6 Опубликовано: 14.04.2020 12:00:14
It shouldn't be related.
#7 Опубликовано: 14.04.2020 12:49:46
Well, anyway, thanks a lot for the responsiveness)
#8 Опубликовано: 14.04.2020 16:59:59
2 343 сообщений из 4 055 понравились пользователям.
Группа: Super Administrator
Hello.
This file looks very strange for me too.
But from what I see it seems that file was correctly written to the file system but another software have wrote its data over this file from file start. So for me it looks like it is some error into another application (something about MS PowerPoint) or file system.
