Mathcad to Smath Question
Mathcad to Smath Question - Сообщения
#1 Опубликовано: 26.07.2016 18:06:01
uncblue
uncblue
2 сообщений из 18 понравились пользователям.
I'm trying to recreate a mathcad calculation in smath and I'm not sure how to make the evaluation "l" which is the resultant distance for each point.
Thanks in advance for any help.
C' Bolt Coefficient.sm (9,81 КиБ) скачан 1274 раз(а).
DownloadDocumentFile.pdf (8,33 КиБ) скачан 814 раз(а).
#2 Опубликовано: 26.07.2016 20:02:04
Ernesto
Ernesto
13 сообщений из 74 понравились пользователям.
Here you go. There might be another way to do this, but this was the first I thought of.
C' Bolt Coefficient revised.sm (11,58 КиБ) скачан 1262 раз(а).
#3 Опубликовано: 26.07.2016 22:55:28
Is that the bolt group ? If so: what else to do ?
#4 Опубликовано: 27.07.2016 11:20:59
uncblue
uncblue
Thanks Ernesto.
@Jean
The next step is to use the C' equation to for each bolt resultant distance to center of group.
I think I've got the C' equation working but I'm sure there is a better way.
C' Bolt Coefficient - 2016-07-27.sm (33,1 КиБ) скачан 1301 раз(а).
#5 Опубликовано: 27.07.2016 12:17:10
uncblue
uncblue
"Uncle Sam",
By inspetion, I kind of understand the C' formula,
just a matter to code Smath. Will be back tonight.
What is Δmax ?
Thanks for the help.
Δmax = Maximum deformation on the bolt farthest from the center of gravity.
Empirical set value = 0.34 in
#6 Опубликовано: 27.07.2016 12:52:08
CBG
CBG
you can use the same formula
Carlos
C' Bolt Coefficient_CBG.sm (13,47 КиБ) скачан 1255 раз(а).
uncblue 29.07.2016 10:54:00
