How to render an equation on viewer?
How to render an equation on viewer? - Сообщения
#1 Опубликовано: 01.07.2021 10:38:09
Oscar Campo
Oscar Campo
I'm working on a simple app for training on Slide Rule use (for my personal purposes), and I can generate problems for practicing that involves multiply, division, pi, x^2, sqrt(x), and so on. But when I run the generated app, the equations are not shown in that fancy style as in SMath.
Please take a Look:
So, maybe anybody has an idea how to render these equations in the viewer?
Oscar
#2 Опубликовано: 01.07.2021 16:31:42
Please take a Look:
Oscar
You can use a snapshot region, but it has decorations in the viewer which you might not want.
Oscar Campo 01.07.2021 17:15:00
#3 Опубликовано: 01.07.2021 17:28:51
Oscar Campo
Oscar Campo
Цитата
You can use a snapshot region, but it has decorations in the viewer, which you might not want.
Thanks for the suggestion, but this technique evaluates any operation/number included in the equation, and I have equations with numbers that I don't need to be evaluated.
#4 Опубликовано: 02.07.2021 10:33:24
Hola Oscar. It is not The solution, but maybe a half of it: the radio button list accept "Symbolic" as an option for view (but not "None", which I guess that it is what you need). BTW maybe some expressions could be showed as you want.
Oscar Campo 03.07.2021 17:38:00
#5 Опубликовано: 03.07.2021 12:41:03
Similarly to X_Y plot, the background color of snapshot
is the active background color [any of 16777216 ... !]
#6 Опубликовано: 03.07.2021 19:57:39
Oscar Campo
Oscar Campo
Thank you for your idea!.
By the way, I'm trying a fancier solution, by using ScriptRegion and a DOS app to render equations to plain text, as you can view:
