Problem with the Linux Installation
Problem with the Linux Installation - Сообщения
#1 Опубликовано: 29.03.2010 02:02:50
bobestes
bobestes
I downloaded the tarball for Linux, but after extracting it will not compile. It seems that it has already been compiled for Windows because it has an exe file. Am I doing something wrong or did somebody zip up the wrong file?
Bob
#2 Опубликовано: 29.03.2010 10:47:29
2 340 сообщений из 4 041 понравились пользователям.
Группа: Super Administrator
Hello. There are already built binaries in the tar.gz - you do not need to compile anything. You just have to run exe file using Mono.
Regards.
#3 Опубликовано: 29.03.2010 15:35:18
bobestes
bobestes
I tried running it from a terminal window, and I received the following error message:
[root@localhost SMathStudioDesktop.0_87.Mono]# mono SMathStudio_Desktop.exe
** (SMathStudio_Desktop.exe:7805): WARNING **: The following assembly referenced
from /home/bob/Downloads/SMathStudioDesktop.0_87.Mono/SMathStudio_Desktop.exe c ould not be loaded:
Assembly: System.Windows.Forms (assemblyref_index=0)
Version: 2.0.0.0
Public Key: b77a5c561934e089
The assembly was not found in the Global Assembly Cache, a path listed in the MO NO_PATH environment variable, or in the location of the executing assembly (/hom e/bob/Downloads/SMathStudioDesktop.0_87.Mono/).
** (SMathStudio_Desktop.exe:7805): WARNING **: Could not load file or assembly ' System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561 934e089' or one of its dependencies.
** (SMathStudio_Desktop.exe:7805): WARNING **: Missing method EnableVisualStyles in assembly /home/bob/Downloads/SMathStudioDesktop.0_87.Mono/SMathStudio_Deskto p.exe, type System.Windows.Forms.Application
Unhandled Exception: System.IO.FileNotFoundException: Could not load file or ass embly 'System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b7 7a5c561934e089' or one of its dependencies.
File name: 'System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyTok en=b77a5c561934e089'
What am I doing wrong?
Bob
#4 Опубликовано: 29.03.2010 18:18:17
Claws
Claws
0 сообщений из 13 понравились пользователям.
Have you installed mono WinForms libs?
/C
#5 Опубликовано: 29.03.2010 19:41:26
bobestes
bobestes
I located and installed mono-winforms, and then I got the following result.
Xlib: extension "Generic Event Extension" missing on display ":0.0".
/root/.gtkrc-2.0:56: Clearlooks configuration option "menuitemstyle" is not supported and will be ignored.
/root/.gtkrc-2.0:57: Clearlooks configuration option "listviewitemstyle" is not supported and will be ignored.
/root/.gtkrc-2.0:58: Clearlooks configuration option "progressbarstyle" is not supported and will be ignored.
I couldn't find anything in the repository labeled Xlib.
Bob
#6 Опубликовано: 30.03.2010 01:58:01
Claws
Claws
As far as I can tell the "Xlib: extension "Generic Event Extension" missing on display ":0.0"." line is just a warning and should be ignored, although you might be able to fix it by installing 'libxcb-event0'
See if this doesn't fix the last three lines:
http://fvue.nl/wiki/Clearlooks_configuration_option_is_not_supported_and_will_be_ignored
#7 Опубликовано: 30.03.2010 04:56:50
bobestes
bobestes
No, that didn't help. The file it talks about (/usr/share/themes/LegacyHuman/gtk-2.0/gtkrc: ) is not on my system. The version of Linux that I'm using is PCLinuxOS 2009.
Bob
#8 Опубликовано: 31.03.2010 10:49:49
Claws
Claws
No, you should check the
/root/.gtkrc-2.0
file instead
#9 Опубликовано: 31.03.2010 19:40:39
bobestes
bobestes
/root/.gtkrc-2.0
file instead
The file is not in root, but I did find it as hdb6/bob/.gtkrc-2.0. That section of the file is not an exact match for the one you referenced. This is what I have.
engine "clearlooks"
# scrollbar_color = "#f2f3ed"
menubarstyle = 0 # 0 = flat, 1 = sunken, 2 = flat gradient
menuitemstyle = 1 # 0 = flat, 1 = 3d-ish (gradient), 2 = 3d-ish (button)
listviewitemstyle = 1 # 0 = flat, 1 = 3d-ish (gradient)
progressbarstyle = 1 # 0 = candy bar, 1 = fancy candy bar, 2 = flat
animation = FALSE
The only change that I could see was to change the menubarstyle from 1 to 0. I can't see any difference in the way it operates. I can run SMath from a terminal window using mono, or I can double click on the .exe file in Konqueror and then open it with mono. The Windows version puts an icon on the desktop, but I haven't been able to get one in PCLOS.
Bob
