Eigenvalues and eigenvectors
Eigenvalues and eigenvectors - Сообщения
#1 Опубликовано: 03.12.2020 17:34:07
Hervandil Santanna
Hervandil Santanna
Is there a built in function for extracting eigenvalues and eigenvectors from matrices?
Thanks
#2 Опубликовано: 03.12.2020 17:58:31
1 125 сообщений из 1 798 понравились пользователям.
Hi. Try this plugin
https://en.smath.com/forum/yaf_postst1918_DotNumerics.aspx
There you have dn_LinAlgEigenvalues and other for Eigenvectors
#3 Опубликовано: 03.12.2020 18:57:42
This is my attempt for do eigenvectors without plugins. Sometimes give better values than dot numerics, and other times fails, because I haven't a simple code for do the pseudo inverse for this code, and use SMath's inverse() which have some bugs.
MEigen with rref.sm (103,07 КиБ) скачан 1151 раз(а).
MEigen with rref.pdf (296,14 КиБ) скачан 752 раз(а).
sergio 04.12.2020 06:21:00
#4 Опубликовано: 03.12.2020 22:50:07
Visit this Companion ...
Maths eigenAll Companion.sm (66,98 КиБ) скачан 1262 раз(а).
#5 Опубликовано: 04.12.2020 08:52:49
Hervandil Santanna
Hervandil Santanna
Thanks everybody.
