How to format vectors?
How to format vectors? - Asking for guidance - Сообщения
#1 Опубликовано: 04.05.2023 01:54:03
TimoS
TimoS
Hello all,
I am having lots of parameters collected to vectors. Almost half of the parameters have subscripts which make the vector having irregular line spacing because subscripts take more height. I need to show the values with a:=[] = [] , but the value vector has regular line spacing. As a consequence the parameters and their values lines do not match and that makes checking the values very difficult: counting on which line a certain parameter is (say line 29) and counting the lines of values and hoping to hit the correct line.
Only way to get the lines even closely matching is to give the vector a name, say M:=[], and then showing it with M=[] and adjusting the font size. Even this doesn't get exact fit when the spacing is irregular and after multiple subscript parameters there is more than one line offset.
So, how to get the listing easily checkable?
#2 Опубликовано: 04.05.2023 08:39:42
So, how to get the listing easily checkable ?
Something like this ? Welcome to Smath Community.
Spline [l,p,c] CLASSROOM_00 Hermite Esplina.sm (42,5 КиБ) скачан 1151 раз(а).
#3 Опубликовано: 04.05.2023 10:44:37
Few more utilities added.
The gray region up there is an Image region, background added.
It has no argument, thus dead and not saved in Smath system.
So, when you open or save the document you have this long message
Can't find ... click OK.
For otherwise specific request, please attach Smath document.
Spline [l,p,c] CLASSROOM_00 Hermite Esplina.sm (69,19 КиБ) скачан 1201 раз(а).
#4 Опубликовано: 04.05.2023 11:05:00
⚜ Kenny Lemens, P.E. ᵂᴵ
Greetings,
... Almost half of the parameters have subscripts which make the vector having irregular line spacing because subscripts take more height. ...
You can embed math into a text region; this feature is showcased on this thread:
https://en.smath.com/forum/yaf_postsm59463_Edit-workflow-for-text-regions-with-embedded-math.aspx#post59463
May this be of Good Help,
- [HIDE-REPLY-THANKS]SK[/HIDE-REPLY-THANKS] Kenny Lemens, P.E. ᵂᴵ
ianlh 04.05.2023 14:32:00, Martin_B 06.05.2023 04:30:00, Oscar Campo 31.10.2023 17:44:00
