Conversion tonf to kgf
Conversion tonf to kgf - It show a different result to the conversion - Сообщения
#1 Опубликовано: 04.01.2021 14:42:40
murilojms@hotmail.com
Hi everybody,
I need a help for two things:
First: i need to use the acceleration as 10m/s^2, does anyone have any idea how to do that?
For example, 1 kgf, must result into 10N.
Second: when i convert 1 ton into kg, i have as result 1tonf=907,1847kgf. WHY????
Thanks for your attention!!!
#2 Опубликовано: 04.01.2021 18:36:51
Hello, the power of ten multiple of 'kgf in SMath is 'tonnef
You can define the acceleration as a variable, a new unit or you can override existing units.
F.e. if you define
'kgf:10*'kg*'m/'s^2
then you'll get
10000*'N=1000@'kgf
