SMath font (v0.98 build 5935)
SMath font (v0.98 build 5935) - Standard font display issue - Сообщения
#1 Опубликовано: 05.10.2016 09:13:12
Jan Claeys
Jan Claeys
2 сообщений из 25 понравились пользователям.
Dear all,
After installing the most recent SMath version on 2 computers, I notice a difference in font display although all settings are the default ones.
This bothers me because sheets I produce at home are totally messed up when I open them at work...
What could be the reason for this? Absence of certain standard Windows fonts?
Thanks in advance for any feedback!
Jan
#2 Опубликовано: 05.10.2016 11:16:49
Hello Jan,
Most probably it might be a known issue about DPI (see here)
#3 Опубликовано: 05.10.2016 11:40:48
Jan Claeys
Jan Claeys
Hello Davide,
Changing my screen size to 100% did the trick (was on 125% - default setting): thank you for your reaction!
Document layout within SMath should be independent from screen size setting, however I'm glad this issue is resolved ;-)
Kind regards,
Jan
#4 Опубликовано: 05.10.2016 11:46:50
You're welcome
I agree, unfortunately it requires more than a simple fix (I have some ideas, though).
