Possible to Change Display on Screen?
Possible to Change Display on Screen? - Сообщения
#1 Опубликовано: 13.01.2024 21:18:45
Mick
Mick
2 сообщений из 18 понравились пользователям.
Is it possible to change the way in which a worksheet is displayed?
It is presented as a series of pages, with gaps in between. Regions will not span the gaps, and so large empty areas appear. I find this very irritating. Is it possible to prevent or hide these gaps, giving a continuous display, effectively using a page of infinite length?
TIA
Jon
#2 Опубликовано: 13.01.2024 23:41:22
Is it possible to change the way in which a worksheet is displayed ?
It is presented as a series of pages, with gaps in between.Regions will not span the gaps, and so large empty areas appear.I find this very irritating.Is it possible to prevent or hide these gaps, giving a continuous display, effectively using a page of infinite length
The Smath default is infinite length. Not convenient for printing, PDF.
Go to Page Setup ... all 9.91 for normal Work Sheet system.
For convenience, separate region(s) from Insert Separator.
#3 Опубликовано: 13.01.2024 23:50:08
ioan92
ioan92
180 сообщений из 120 понравились пользователям.
Hi Jon,
You can choose the printing option: "No bounds"
from the right side of the page bottom:
In this way you can settle your work as you want.
Ioan
#4 Опубликовано: 14.01.2024 02:26:02
Mick
Mick
Thank you Ioan, that's exactly what I need.
I'd never even noticed the bit at the bottom RH corner. Sometimes I get the feeling that one can do a lot in Smath, but it's a bit like an MI5 puzzle to find some things!
Thanks again.
Jon
