Spool => File *.dat ... HowTo
Spool => File *.dat ... HowTo - Spool => File *.dat ... HowTo - Сообщения
#1 Опубликовано: 11.12.2017 13:33:37
I pedaled on that one, not to avail. Maybe there is no way ?
Toke just little bit from NotePad ... it returns full expansion
instead of the two cols only numerical values.
Mathcad WRITEPRN does it fine ... Smath missing WRITEPRN
As you open the work sheet, it should create the file system.
Thanks "All Doctors" if you can reconciliate this patient.
Random Chirp Outliers.sm (119,38 КиБ) скачан 1243 раз(а).
#2 Опубликовано: 12.12.2017 15:59:12
If you have the DataExchange plugin and you want a numerical output file you might try fwrite() or exportData.CSV()
