SMath sudden interruption
SMath sudden interruption - Unexpected interruption with data lost. - Сообщения
#1 Опубликовано: 12.09.2024 23:53:05
ioan92
ioan92
178 сообщений из 114 понравились пользователям.
Hello Everybody,
Sometimes I faced a Smath behavior that I do not know how to interpret.
SMath is totally freezed and data are lost. The received message is:
1.I wonder if somebody else met the same problem.
2.I’m interested about the reason for this artifact?
3.I'd like to know if I had done something abnormal and especially I'd like to know how to avoid this;
Thanks for your attention,
Ioan
#2 Опубликовано: 13.09.2024 15:00:43
1 438 сообщений из 2 920 понравились пользователям.
Never happened to me.
Whatever the issue with license check is, this shouldn't happen.
When you log in there is a procedure for a offline activation, you might try that to avoid this issue.
ioan92 13.09.2024 20:02:00
#3 Опубликовано: 13.09.2024 20:34:37
ioan92
ioan92
Thanks for the advice.
I registrated SMath offline.
Whith this procedure, the admitted registration is valid for max 12 months.
Probably, the procedure has to be repeated each 12 month ? My licence is: lifetime.
Thanks again
#4 Опубликовано: 16.09.2024 05:12:58
That's my interpretation as well (I checked and I have the same options)
ioan92 16.09.2024 15:15:00
