Get an exception typing in a vector variable name
Get an exception typing in a vector variable name - After a recalculate, typing in a vector variable name gives an exception - Сообщения
#1 Опубликовано: 02.03.2026 10:06:24
Chris C
Chris C
smException.sm (5,92 КиБ) скачан 710 раз(а).smath-exception.doc (31,5 КиБ) скачан 505 раз(а).
I get an exception while typing in a variable name into the worksheet, --after-- a recalculate. Not before. Anyone any idea what might be happening? The exception looks to depend on what's in the function call - for example, it's fine if N is set to 25, and fine on different variants of the function algebra. It's nothing to do with the variable name itself, it's not a reserved name conflict. It's repeatable and does it in Windows 10 and Windows 7. Sm and exception report included.
#2 Опубликовано: 03.03.2026 13:12:08
I can confirm the issue (and as you say, it works just fine with N=25).
From the error stack seems related to the handling of ChildrenRegions, even though the document seems has none of those.
#3 Опубликовано: 03.03.2026 15:15:39
Chris C
Chris C
Thank you Davide. Further probing shows it might be related to optimization : if I turn the vector generating loop optimisation away from symbolic to either numeric or none, the exceptions stop. Although the optimised and non-optimised variants do look to be very similar, so that might be spurious. This all originated in a larger document, with two same sized arrays generated by two similar function calls : one generated an exception when typing the vector name, the other didn't. N was originally 32, there are lots of values of N that don't cause an exception.
