PDF Create
PDF Create - PDF Create - Сообщения
#1 Опубликовано: 15.05.2016 23:24:17
As easy to create PDF in Smath as it is in Mathcad.
You must have a PDF tool intalled in your PC [a virtual printer].
In Smath:
1. Print
2. in the print menu, scroll for "ScanSoft PDF Create"
3. in the print menu "Print to file"
4. document name/location [by user]
5. read from Adobe XI
Done ! "ScanSoft" is my Nuance PDF create/read
CutePDF, PDF 995, PDF Creator ... are freeware
PDF Test.pdf (33,6 КиБ) скачан 1735 раз(а).
#2 Опубликовано: 16.05.2016 13:25:19
Alexander O. Melnik
Alexander O. Melnik
What interests me here is how did Scan Soft or CutePDF interpret that PLOT region is vector graphics? I could have used similar approach for .SVG images within .sm workbook... If I knew how..
#3 Опубликовано: 16.05.2016 18:09:08
Mike Kaganski
Mike Kaganski
They didn't interpret it at all. When plotting, it's SMath that sends either vector, or raster data to the printer driver. It tells each region to draw itself to printer canvas, and they do it themselves either by sending low-level lineto-like vectors, or by playing with pixels.
С уважением, Михаил Каганский
#4 Опубликовано: 16.05.2016 20:18:31
Well explained mike !
In other words, the PC [black box] contains only data.
Same thing with letters, they are only matrix [small, capital, fonts ...]
They are displayed via Bézier splines or other SVG transforms.
Same thing with images 1/1 RGB.
Cheers, Jean
