ZedGraph Question
ZedGraph Question - No negative scale markers - Сообщения
#1 Опубликовано: 27.02.2025 05:52:38
RegRetired
RegRetired
8 сообщений из 144 понравились пользователям.
In the following ZedGraph, there are no major scaler markers in the negative y axis region. Have I missed an important parameter in setting up the graph?
ZEDGRAPH QUESTION.sm (38,86 КиБ) скачан 1745 раз(а).
Thanks,
Reg
Reg CurryLoveland, CO
#2 Опубликовано: 27.02.2025 11:54:24
Hi Reg. Logarithmic scales do not allow negative values. Therefore, they are not shown on either axis, since both have logarithmic scales.
#3 Опубликовано: 27.02.2025 12:05:45
RegRetired
RegRetired
Hi Alvaro,
The vertical scale is set to linear.
I fixed the later time values to -300.
Reg
#4 Опубликовано: 27.02.2025 13:32:03
Oh, yes! You're right. I see "E" and think in logs. Please modify this parameter:
RegC 27.02.2025 13:54:00
#5 Опубликовано: 27.02.2025 13:54:16
RegRetired
RegRetired
Hi Alvaro,
Thanks much!
ZedGraph is necessary for any log scales as far as I can tell. I has more options than I can keep track of. :>D
Thanks again,
Reg
