"on error" test image rotate
"on error" test image rotate - "on error" test image rotate - Сообщения
#1 Опубликовано: 16.04.2016 14:42:32
Hello Mike,
If you can make it work at the "on error" that Smath 5346 does not have
the Smath community will heritate a nice piece of work that I heritated
from Paul W. [Mathcad 11 Collaboratory]. If there is a way to make it
work in 5346, I will most appreciate. The R, G, B are all in the collapsed
areas, nothing to download. The coding stops at the empty place holders.
Thanks for your kindly cooperation, good luck.
Rotate Image.sm (431,26 КиБ) скачан 1531 раз(а).
#2 Опубликовано: 16.04.2016 19:50:06
Mike Kaganski
Mike Kaganski
rotate() tries to get fourth col of a matrix having only two cols:
trace.sm (100,24 КиБ) скачан 1521 раз(а).
Actually, I didn't try to understand the algo yet, so I have no clue how to improve it.
Edit:
in the original algo, there's no line like
s:augment(col(s,2),col(s,4))
Removing it gives another error: j becomes -14, and this index isn't OK as a matrix col.
Edit 2: here it is, should work for 5346: Rotate Image.sm (407,7 КиБ) скачан 1540 раз(а). (updated for 2x speed using eval()).
Edit: and here is the colored version (great thanks to Alex Melnik): Rotate Image+color.sm (414,52 КиБ) скачан 1531 раз(а).
С уважением, Михаил Каганский
