Finding Roots of a large system of equations
Finding Roots of a large system of equations - Having trouble with the syntax - Сообщения
#1 Опубликовано: 23.09.2024 05:34:57
RegRetired
RegRetired
8 сообщений из 144 понравились пользователям.
See attached sm file.
I am trying to find the k values of alpha that are roots of the system of k transcendental equations. I don't understand the required syntax.
I have the equivalent MATHCAD 15 file if that is helpful to anyone.
Thanks for all help.
Reg
LITTLE BOY LAMBDA AND ALPHA.sm (86,48 КиБ) скачан 1616 раз(а).
Reg CurryLoveland, CO
#2 Опубликовано: 23.09.2024 09:18:02
Hi Reg. You can try this.
LITTLE BOY LAMBDA AND ALPHA.sm (93,57 КиБ) скачан 1666 раз(а).
#3 Опубликовано: 23.09.2024 09:58:57
RegRetired
RegRetired
Alvaro,
Thanks. I will give that a try. I found a couple of typos in my definition of the elements of F. But, I will fix that and try your method.
I got a little further using the solve function; however, I am having trouble getting it to plot.
LITTLE BOY LAMBDA AND ALPHA.sm (63,61 КиБ) скачан 1626 раз(а).
Thanks again,
Reg
