Exporting PDFs
Exporting PDFs - Сообщения
#1 Опубликовано: 06.10.2023 11:09:57
Oichi
Oichi
4 сообщений из 35 понравились пользователям.
Hello SMath users, I remember like few months ago I was able to export my files in PDF format but while searching the plugins now I didnt find the PDF plugin for free, The free plugin is not there anymore?
#2 Опубликовано: 07.10.2023 08:35:30
The free plugin is not there anymore ?
CutePDF was freeware, mine 23 years old works fine.
It renders 1/1 quality.
#3 Опубликовано: 07.10.2023 09:47:05
Oichi
Oichi
It converts from .sm to .pdf?
ruddy 11.10.2025 01:00:01
#4 Опубликовано: 07.10.2023 10:38:03
Basile
Basile
8 сообщений из 172 понравились пользователям.
Save As
Select *.pdf
Hope it helps,
Basile
#5 Опубликовано: 07.10.2023 10:45:09
Oichi
Oichi
I can't see pdf anymore in "save as"
#6 Опубликовано: 07.10.2023 12:59:48
francesco rapuano
francesco rapuano
15 сообщений из 38 понравились пользователям.
I guess that at first you need to install .PDF reader like Foxit Reader or similar freeware .
After the installation of such a type of SW you sould see in any application the possibility to save/print in .PDF format .
Hope this help, take care
Franco
#7 Опубликовано: 07.10.2023 13:12:23
1 353 сообщений из 2 264 понравились пользователям.
You may use a pdf printer driver.
I made some experiments: Deactivated my copy of SMath (log out), disabled the PDF Files plugin, restarted SMath.
- PDF not listed any more under "Save As"
- Microsoft Print to PDF throws an error
- PDF 24 printer driver succeeds in producing a PDF (with watermark saying "free version of SMath, no commercial use" )
- PDF Exchange Viewer printer driver succeeds as well, yet comes with it's own ugly watermarks in the free version.
#8 Опубликовано: 08.10.2023 08:33:37
Try Print instead of "Save as"
#9 Опубликовано: 10.10.2023 20:03:34
⚜ Kenny Lemens, P.E. ᵂᴵ
85 сообщений из 179 понравились пользователям.
Greetings,
With the evolution of SMath's EULA, those supplementary plugins created by Andrey are no longer available to Basic accounts (Please take note of the "Locked" icon):
This plugin can still be used, but it is limited to user accounts with Extended Functionality:
It is possible in the last upgrade you made to the SMath Studio; you 'lost' the permissions to use the 「PDF Files Plugin」 if you don't have an activated account.
Solution:
- Upgrade/activate your Smath account to access this plugin.
- Use the "PRINT" command and select a PDF driver (which typically comes installed with your PDF application (e.g., Adobe, Nitro, Bluebeam, etc. )
May this be of Good Help;
