problem with if
problem with if - programming if does not show else - Сообщения
#1 Опубликовано: 24.09.2022 15:02:57
Carlos Couto
Carlos Couto
Maybe this is a very dumb question but how can I add a "if else" structure?
When I click the "if" in the programming toolbar no "else" is added.
#2 Опубликовано: 24.09.2022 15:23:49
Carlos Couto
Carlos Couto
OK, this happens in last version. I checked in build 8151 it does not occur, seems like a bug.
#3 Опубликовано: 24.09.2022 18:32:34
1 336 сообщений из 2 250 понравились пользователям.
The if function now has a variable number of operands. The side panel and the dynamic assistant insert the binary form by default. Just type one or more argument separators immediately after insterting the function and see what happens. Likewise you can delete operators by typing backspace.
The binary form is a compact notation if you don't need the else clause.
However, I prefer the cases() function from the custom functions plugin, because it is more compact.
Oscar Campo 21.10.2022 12:29:00
#4 Опубликовано: 06.10.2022 23:21:22
Norm Schutzkus
Norm Schutzkus
9 сообщений из 90 понравились пользователям.
Ah-h! Good to know. I was scratching my head on this one!
Thank you!
Norm
