pH Solution
pH Solution - pH Solution - Сообщения
#1 Опубликовано: 10.07.2018 19:33:33
Works fine.
Inst_pH Solution.sm (24,51 КиБ) скачан 1219 раз(а).
#2 Опубликовано: 10.07.2018 23:36:55
Works fine.
... refreshed, optimized calculation timing
Added the buffered plot to be splined for + values.
Inst_pH Solution.sm (44,9 КиБ) скачан 1256 раз(а)....refreshed/augmented
#3 Опубликовано: 11.07.2018 04:42:18
Hello Jean,
For me, the first plot is working
but the second is not - cases() is complaining.
I could see that sigma2 went nuts (do not know why) and put eval() in front of it
I do not have the explanation of this - might be a bug.
#4 Опубликовано: 11.07.2018 08:09:43
1. Can't understand the error cases(,) [6671]
2. Make unit K was first problem , done well.
3. Doctoring for the spikes works and accelerates calculation timing.
Inst_pH Solution Copy.sm (46,65 КиБ) скачан 1273 раз(а).
#5 Опубликовано: 11.07.2018 19:21:14
Ruben Sidranski
Ruben Sidranski
Can you explain sheet. I was looking at creating a Langelier Saturation Index (LSI) for quick analysis and this appears to be going in that direction
#6 Опубликовано: 11.07.2018 23:16:55
Can you explain sheet.I was looking at creating a Langelier Saturation Index (LSI) for quick analysis and this appears to be going in that direction
The program is a dual iterative solver.
Give some more about Langelier saturation index.
#7 Опубликовано: 11.07.2018 23:49:28
Langelier saturation index [LI] has nothing to do wrt unbuffered.
As it looks, there are lot of those things already tabulated.
Wait and see if you can come up with some interesting stuff.
