CoolProp Air
CoolProp Air - Why is there such a big difference? - Сообщения
#1 Опубликовано: 13.05.2026 15:29:48
Valery Ochkov
Valery Ochkov
67 сообщений из 713 понравились пользователям.
Hi David!
Thanks for the Coll Prop!
1 Why is there such a big difference?
2 Do you know why there is 23% oxygen in the air?
O2-N2-Air.sm (11,32 КиБ) скачан 571 раз(а).
#2 Опубликовано: 14.05.2026 01:43:45
Hi Valery. There are different reference states, that is, with zero enthalpy and entropy. These could be harmonized using CoolProp_set_reference_stateS or CoolProp_set_reference_stateD, but I don't know how to use them, or they don't work for me. By the way, for any application, the important thing will always be Δs, not s.
This post is 10 years old, where I'm asking about how to use them:
https://smath.com/en-US/forum/topic/gcKGsU/CoolProp-Wrapper#msg111998
Отредактировано 14.05.2026 01:58:44
Valery Ochkov 14.05.2026 03:55:44
#3 Опубликовано: 14.05.2026 03:57:20
Valery Ochkov
Valery Ochkov
Thanks Alvaro!
And what can you say about the maximum at 20% O2?
#4 Опубликовано: 14.05.2026 13:06:54
Hi Valery. I suppose we would have to apply the Second Law of Thermodynamics δQrev = T*ds. Since it is close to a maximum, ds has to be small, and I don't know if this should be interpreted as a maximum in s implying a maximum in the system's capacity to handle heat reversibly, optimizing the efficiency of systems where air is the working fluid, as in internal combustion engines, or vice versa!
I assume that this also has important consequences in biology, but the flexibility of the walls complicates everything, as in the case of veins, which are not pipes because they expand and contract considerably, and the lungs, where the alveoli are also very flexible.
Отредактировано 14.05.2026 13:19:11
Valery Ochkov 14.05.2026 18:41:48
