Open file bug
Open file bug - Index was outside the bounds of the array - Сообщения
#1 Опубликовано: 09.12.2014 08:11:38
TienCuong
TienCuong
I created a Smath Studio file yesterday
with losts of calculations in it. But today
I could not open the file again. A message box
appeared saying "Index was outside the bounds of the array"
I re-did the work and saved it.
A few hours later, I could not open it again. Same problem
had occurred.
Hope you can fix this soon - regards
(PS: I am using the latest version - 0.97)
#2 Опубликовано: 09.12.2014 08:43:51
brotjob
brotjob
7 сообщений из 71 понравились пользователям.
Try to open the file with automatic recalculation disabled. Maybe you can locate the problem then.
#3 Опубликовано: 09.12.2014 09:10:35
1 440 сообщений из 2 929 понравились пользователям.
If the brotjob suggestion fails, could you post the broken file?
#4 Опубликовано: 09.12.2014 22:15:17
TienCuong
TienCuong
Ah ha ..today it is working again.
But I should have added that I was working at two different computers
sharing the same DropBox account. The file was put in the Dropbox,
and it was synchronised to my Home computer. I couldn't open the file
at the Home computer, but I could open it at the Work computer where I originally
created the file. A bit weird though/. Can you please tell me how to post the file to the forum ?. Thank you all.
#5 Опубликовано: 10.12.2014 07:34:26
Just click on the rightmost button on the top of your message or check the attach button when you post a new one.
If the file is too big you can zip it or you can add a dropbox link
