Trouble with Snippets
Trouble with Snippets - Ward - Сообщения
#1 Опубликовано: 12.06.2012 09:57:52
Ward
Ward
I moved a few files into the snippet directory. When I try to import them they do not show up on the list. I tried restart. I also noticed they are missing when I try to manually open them using File-Open.
#2 Опубликовано: 12.06.2012 10:53:38
Oscar Campo
Oscar Campo
Some short answres could help...
Which version of SMath are you using? If you are working on windows Vista/7 platform, have you administrator privileges?
Oscar
#3 Опубликовано: 12.06.2012 13:07:27
Ward
Ward
Latest version of SMath on WinXP.
#4 Опубликовано: 12.06.2012 14:05:56
2 342 сообщений из 4 041 понравились пользователям.
Группа: Super Administrator
Did you try to set snippet Shortcut using "File" > "Properties"?
#5 Опубликовано: 12.06.2012 15:51:38
Ward
Ward
I figured it out, I had to open the file and then save it in the snippets directory. A drag and drop does not work. Thanks for the help.
