Disable Evaluation
Disable Evaluation - In a part of program - Сообщения
#1 Опубликовано: 27.05.2023 05:05:26
Valery Ochkov
Valery Ochkov
67 сообщений из 708 понравились пользователям.
It will be good!
#2 Опубликовано: 27.05.2023 08:07:26
It will be good !
We have it algo style...
Lot more powerful/simpler, composed @ will.
Maths algo ADVANCED.sm (15,43 КиБ) скачан 1632 раз(а).
#3 Опубликовано: 27.05.2023 08:46:20
Oscar Campo
Oscar Campo
It will be good!...
Putting that block between quotation marks ("..." ) is a tricky option. That converts that block into a text or a "commentary" to your code. When you need that block to be evaluated, copy the text between the quotation marks and paste it into the code.
Example:
Now the block is a "commentary":
Revert the process to enable evaluation
Best,
Oscar
