Paste on the canvas causes unhandled exception
Paste on the canvas causes unhandled exception - Сообщения
#1 Опубликовано: 12.02.2014 13:25:25
This happens when the clipboard contains strings with spaces (Win7 x64 / SMath Studio 0.97)
P.S. this not happens using the nightly build 0.96.4909
Цитата
Le informazioni su come richiamare il debug JIT (Just-In-Time) anziché questa finestra
sono riportate in fondo al messaggio.
************** Testo dell'eccezione **************
System.NullReferenceException: object reference not set to an instance of an object.
in SMath.Control.Worksheet.(String )
in SMath.Control.Worksheet.Insert(String value)
in SMath.Control.WorksheetControl.OnKeyDown(KeyEventArgs e)
in System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
in System.Windows.Forms.Control.WmKeyChar(Message& m)
in System.Windows.Forms.Control.WndProc(Message& m)
in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
best regards,
Davide
#2 Опубликовано: 12.02.2014 16:05:45
update: I notice the same issue even when I copy and paste a string with spaces from a text area to the canvas (so probably the HTML data is not the cause)
#3 Опубликовано: 12.02.2014 17:10:56
2 343 сообщений из 4 044 понравились пользователям.
Группа: Super Administrator
Cannot reproduce on latest 0.97 (tried the same text you shown on screenshot and some others).
May it be caused by some plug-in installed? If you will find it out I hope to find a way to prevent such kind of problems in future.
Davide Carpi 12.02.2014 19:20:00
#4 Опубликовано: 12.02.2014 17:32:08
I can confirm that strange things happen:
1. Open installed 0.97 with nearly all plugins enabled.
2. paste "ddd " to the canvas - a hyperlink region with that string appears
3. Switch off Hyperlink Region in the extension manager
4. paste "ddd " again - a snapshot region appears
5. Disable snapshot region as well
6. Again pasting "ddd " - a crash happens with the following details:
Показать спойлер
I can repeat that.
What I cannot repeat: sometimes pasting creates a conditionally formatted label, but I did not yet recognize the pattern how to invoke that.
#5 Опубликовано: 12.02.2014 18:05:16
Thank you Martin and Andrey,
I've removed all the plugins and I can reproduce what Martin said...
The crash is caused by a third plugin, DevelopmentTools .... the behavior of the Hyperlink and Snapshot regions is incredible... I'll investigate a little bit more
#6 Опубликовано: 12.02.2014 18:25:13
OK my diagnosis:
- DevelopmentTools:
This code cause the crash (here the plugin doesn't override the Paste(IClipboardManager clipboard) function)
public string[] SupportedClipboardFormats
	get { return new string[] { DataFormats.UnicodeText }; }
This solve the problem (at least for the users):
	get { return new string[0]; }
Hyperlink & Snapshot Regions:
- SMath triggers the public override bool Paste(IClipboardManager clipboard) of any available plugin, even if there aren't regions on the canvas (but this should happens only if a region exists and is focused)
Andrey Ivashov 12.02.2014 18:39:00
#7 Опубликовано: 12.02.2014 18:39:15
Thank you! I will implement fix asap.
Davide Carpi 12.02.2014 19:13:00
#8 Опубликовано: 12.02.2014 20:18:35
Thank you very much Andrey
I don't have noticed the bug in the front-end, but I've fixed the code as for the Development tools and I've pushed in the EM an update
