rank
rank - Сообщения
#1 Опубликовано: 19.04.2020 08:24:42
haweHofmann
haweHofmann
3 сообщений из 32 понравились пользователям.
Hallo zusammen,
DimEigenraum: (n-rank(A-λ*E))=1@#
should be 2
some steps of elementary row additions later
is 2
https://de.smath.com/cloud/sheet/vooDFR4FbP
any idea whats wrong?
#2 Опубликовано: 19.04.2020 10:08:10
This link doesn't works, be sure to use the share button link (on the right of the save button), because the address bar link is restricted to the author only.
#3 Опубликовано: 19.04.2020 10:19:42
haweHofmann
haweHofmann
Upps, sorry
Made a link
https://de.smath.com/cloud/worksheet/3BgYDE7e,
Maxima pure
(%i6) A: matrix([1,1,1,-1,0],[0,1,0,0,1],[0,0,0,1,0],[0,0,-1,2,1],[0,0,0,0,1])$
(%i7) A-1*ident(5)$
(%i5) rank(A-1*ident(5));
(%o5) 3
but
Maxima(rank(A-1*identity(5)))=4
or
#4 Опубликовано: 19.04.2020 13:37:27
The referenced sheet seems to use Maxima(). This doesn't work, as third party plug-ins aren't available in the cloud version.
It is better to attach such files here.
#5 Опубликовано: 19.04.2020 13:50:54
rank(M) ... matrix rank is Smath built-in.
Here is a most precious application.
Matrix PseudoInverse.sm (111,21 КиБ) скачан 1195 раз(а).
#6 Опубликовано: 19.04.2020 14:09:48
haweHofmann
haweHofmann
and in how far do your example explain the incorrect calculation
the Maxima part calculate the single eigenvalue which is set manually in cloud version
SMath Studio 0.99.6884 - [JordanMatrix5x5-5fachEW-HV.1.2.Stufe.sm_]_2020-04-19_19-07-08.jpg
JordanMatrix5x5-5fachEW-HV.1.2.Stufe .sm (47,19 КиБ) скачан 1160 раз(а).
#7 Опубликовано: 19.04.2020 23:51:44
Hi. You're right, it's a bug and there are no way to make this works (numerical nor symbolic):
First column is zero and 3th = - 4th columns, so can't be rank = 4.
#8 Опубликовано: 20.04.2020 11:51:33
Just advanced maths above the classroom.
Your example replies bug from incorrectly threaded input.
As given, your [5*5] matrix has no mathematical meaning.
Page1 rank.sm (11,74 КиБ) скачан 1328 раз(а).
sergio 20.04.2020 12:15:00
#9 Опубликовано: 20.04.2020 14:19:49
... clean the bugger
What application do you have for "rank(,) ?
Don't confuse with Rank in Data Analysis.
rref [Row Reduce Echelon Function] is a damned long monkey business.
Has it been done in Smath ... Watson ?
#10 Опубликовано: 20.04.2020 14:51:32
... Rank(V)
Given a set of data values, the rank of each value is the position
at which that value appears in a sorted list of the data.
When values repeat, the rank is an average of the indices where
the value occurs after sorting.
