Matrix function (conditional)
Matrix function (conditional) - Сообщения
#1 Опубликовано: 20.09.2019 15:34:48
XiuPer
XiuPer
I'm trying to write a function that I can use to calculate the surface area. The function is to be based on data from a matrix with n elements
I ran out of ideas. I guess the problem is in a loop.
I attach a file and an image.
I will be grateful for your help.
Integral.sm (7,23 КиБ) скачан 1140 раз(а).
#2 Опубликовано: 20.09.2019 17:22:30
Arie
Arie
You can define piecewise function this way. Haven't figured out integration yet. Built in int() function doesn't seem to work.
Piecewise Function.sm (6,82 КиБ) скачан 1147 раз(а).
#3 Опубликовано: 20.09.2019 19:56:29
That was lavishly exemplified few hours ago.
Your drawing needs some project intention about,
i.e: what is what for what.
#4 Опубликовано: 20.09.2019 20:15:38
Latest version is all white. Could discover the blank regions,
framed the regions, added background.
#5 Опубликовано: 20.09.2019 20:37:44
#6 Опубликовано: 20.09.2019 20:46:37
You can try something like this
#7 Опубликовано: 20.09.2019 23:29:09
Annotate the drawing [what is what in there], and what wort what.
MatrixUnknown.sm (9,19 КиБ) скачан 1144 раз(а).
#8 Опубликовано: 21.09.2019 04:37:10
XiuPer
XiuPer
Thank you guys for your answers,
I will try to explain what I need.
Depending on the soil layers, I have a graph similar to the picture. At a later stage, I want to divide this chart into equal pieces (for example 0.25 m or 0.5m) to obtain "soil springs".
To simplify the example, I assumed that the elements of the K matrix are constant.
#9 Опубликовано: 21.09.2019 05:47:47
uint.sm (9,71 КиБ) скачан 1150 раз(а).
frapuano 21.09.2019 07:05:00, sergio 21.09.2019 08:26:00
#10 Опубликовано: 21.09.2019 11:23:03
OK ... from there, apply your skill to produce the Cartesian graph
of the piecewise soil. No problem to integrate.
Integration of discontinuous functions is deceiving.
Two models attached. The Romberg-Simpson is more accurate.
Example 2, the integration is known by inspection.
Isn't deceiving Simpson is not so good !
Integrate Discontinuous_2.sm (131,93 КиБ) скачан 1201 раз(а).
#11 Опубликовано: 21.09.2019 14:12:23
Total integration is often what the project needs.
Most Engineering projects require the evolution of the integration,
i.e: the cumulative integration.
The attached takes Martin data set, convex Hermite
that you can fillet [sub:=,] and populate at will [mesh 't'].
The latest step is the FD integration [Finite Differences].
The graph shows the evolution of the integration.
The end point of the cumulative = total integration
from any other best/applicable numerical integrator.
Except for trivial cases no numerical integration is exact.
FD integration is always very accurate [kind of yardstick].
Hermite polyline is very similar to CAD systems.
Please, come back on that "Soil project".
Integrate Discontinuous_3 [HermiteSpline, FD].sm (49,69 КиБ) скачан 1011 раз(а).
#12 Опубликовано: 21.09.2019 14:16:46
True Viacheslav: ODE integrator(s) are very excellent.
Thanks for your input.
#13 Опубликовано: 21.09.2019 17:18:55
... some didactic added.
OBSERVE: before the CAS numerical integration,
integration was FD [Finite Differences].
Read: F.B. Hildebrand.
Integrate Discontinuous_3 [HermiteSpline, FD].sm (114,63 КиБ) скачан 1025 раз(а).
#14 Опубликовано: 22.09.2019 06:57:11
XiuPer
XiuPer
Thank you very much,
(btw the "thank" button on this page does not work)
The idea of ​​using linterp is actually much better instead of a loop.
Below is the file with the result I needed.
Final springs.sm (20,64 КиБ) скачан 1174 раз(а).
#15 Опубликовано: 22.09.2019 09:43:08
The idea of using linterp is actually much better instead of a loop.
The "Tanks" button used to work years ago, not any more.
Good work ... two comments:
1. subscript is confusing with sub-sub index.
Very many projects are sub-sub indexed.
Reserve subscript as tutorial [exemplified].
2. variable name confusing with number is another killer.
you had 1:=max(X).
SS7030 was reputed good version, compatible SS 6179.
Final springs_1.sm (24,73 КиБ) скачан 1176 раз(а).
#16 Опубликовано: 22.09.2019 13:56:55
... for convenience and publishing:
you can sub-space [at will] your calculated segments.
From there, you may obtain the cumulative integration
from the FD as offered before.
Final springs_1.sm (42,69 КиБ) скачан 1161 раз(а).
#17 Опубликовано: 22.09.2019 15:32:32
... directly from the sampled data.
Subspace is a great utility.
Soil Simplifed from Sampled Data.sm (18,09 КиБ) скачан 1216 раз(а).
