Units conversion
Units conversion - Сообщения
#1 Опубликовано: 06.04.2010 00:09:15
dnsalyer
dnsalyer
Just started using the beta program. This is a wonderful project and is very helpful. Units conversion is a major reason for my wanting to use the software. Thanks very much for working on this.
I discovered a problem with the way the volumetric unit gallons (gal) are handled. It should be 3.785e10^-3 m^3, but SMath build 3728 derives this as 3785 m^3, a factor of 10^6 different.
Thanks,
Dave S.
#2 Опубликовано: 06.04.2010 14:31:24
maweilian
maweilian
5 сообщений из 103 понравились пользователям.
Thanks,
Dave S.
Yes, I also confirm that the conversion performed by Smath is incorrect here; 1 gallon should equal 0.00378541178 meters cubed.
Will
#3 Опубликовано: 06.04.2010 14:58:50
Группа: Super Administrator
Thank you. Will fix today.
#4 Опубликовано: 06.04.2010 17:14:26
Fixed.
