1 страниц (6 вхождений)
Sometimes VERY slow calculation time in program loops - 10 loops may be ok, but geometric/exponential slowness from larger N - Сообщения
calculation time problem-2.sm (14,35 КиБ) скачан 1373 раз(а).
hi all,
I am new to SMath but have 20 years experience with similar software.
I've struggled to find some problems when doing loops in a program. The math is very simple but
I am seeing calculating times in the seconds to minutes for things that should be far under 1 second.
Am I doing something wrong or is there some kind of issue. I first saw this problem in Linux
but this recent example is on Windows 7, SMath Studio Desktop 64-bit 0.98 build 6179
The attached file will calculate quickly as it stands, but there are disabled math regions highlighted
in RED that if enabled will dramatically slow down the calculation.
I have tried some optimizations such as setting the calculation to Numeric (not Symbolic) and
though I don't understand it, I wrapped my loop functions inside eval().
any ideas are greatly appreciated
mark
hi all,
mark
Hello [userlink]themzlab[/userlink],
attached a faster version, <0.4s on my machine; in light blue modifications and suggestions
calculation time problem-2.sm (15,66 КиБ) скачан 1488 раз(а).
Reason is that you are using procedures (list of commands behind a line() function immediatly on the RHS of an assignment); these aren't evaluated until you use them (hover the mouse over the definition to see what is stored in the engine). Since they doesn't depends from variables defined after them, you can evaluate each one at once assigning to a new variable (with the same name in the example above, but this doesn't matter, you can choose the name you want and then use this new variable in calculations to not evaluate the whole procedure again and again).
Thanks so much Davide for the quick reply. That correction does work!
I have a follow up question, does using the function eval() on the expressions in the loop do anything in this context (inside that loop inside the program?).
WroteI am new to SMath but have 20 years experience with similar software.
Which similar software ? Never mind.
The attached PID Model may contain some useful informations.
calculation time problem-2.sm (17,88 КиБ) скачан 1325 раз(а).
Inst_PID [MCD Model].sm (176,2 КиБ) скачан 1107 раз(а).
Mark 15.02.2017 18:25:00
You are welcome
it depends.
eval() triggers a numerical evaluation of his content; in other words, it returns a number with a 15 digits precision. In a heavy loop might be useful to make it faster, if his content contains a stack of operations from previous loops or functions that behaves differently in numerical or symbolical mode. If eval() is applied on a function that is pure numerical, it changes nothing.
WroteI have a follow up question, does using the function eval() on the expressions in the loop do anything in this context (inside that loop inside the program?).
it depends.
The rule about eval(,) is that there is no fixed rule,
whereas it associates with the suite of the project.
Reach the bottom of the attached work sheet, read at
the big turquoise arrow.
Image RGBYCM.sm (292,51 КиБ) скачан 1348 раз(а).
