Adding degC and Kelvin
Adding degC and Kelvin - Adding Kelvin and DegC gives invalid result. - Сообщения
#1 Опубликовано: 03.11.2015 04:17:53
Bani
Bani
Hi
When I do the following, the results are not correct:
Here is the file I used:
Fault.sm (2,62 КиБ) скачан 1269 раз(а).
Bani Greyling
#2 Опубликовано: 03.11.2015 05:36:13
You must use the unit of measurement for temperature differences
[albumimg]1387[/albumimg]
#3 Опубликовано: 03.11.2015 05:46:23
Bani
Bani
Thanks
I understand now what is happening: 300K + 10C -> 300K + 283.15K = 583.15K
Bani
#4 Опубликовано: 03.11.2015 22:47:28
300K 10C -
_______________________________________
Your understanding is correct: the unit of temperature is °K.
Working with unit means consistant system, particularly true
working trig functions.
That freeware "Uconeer 2.4" from Katmar is most precious.
Some smart decided the triple point of water that was 0 °C
is now 0.01°C
Davide Carpi 04.11.2015 20:35:00
