Varying results for trig function
Varying results for trig function - Сообщения
#1 Опубликовано: 27.02.2012 12:09:48
scottg
scottg
I found a minor problem with trigonometric functions. The following problem occurs only for a value of 30 degrees, as you can see the value of sin evaluates differently depending on the construction of the math. And only when I am modifying the value of phi in expression shown.
It would not be a problem if a value of phi = 30 was not common in geotechnical engineering.
[MATH]φ:30deg[/MATH]
[MATH=eng]γ:1.3[/MATH]
[MATH=eng]δ:atan(tan(φ)/γ)[/MATH]
[MATH=eng]δ=23.9468@'deg[/MATH]
[MATH=eng]β:sin(δ)[/MATH]
[MATH=eng]β=1.2177[/MATH]
[MATH=eng]sin(δ)=0.4059[/MATH]
Any thoughts?
#2 Опубликовано: 27.02.2012 15:13:33
The solution is to apply Optimization|Numeric or None on the region:
[MATH=eng]δ←atan(tan(φ)/γ)[/MATH]
This is a common advice to do first when you need just the numerical values.
BTW, the degrees does not work properly in v0.92
#3 Опубликовано: 27.02.2012 15:18:41
2 343 сообщений из 4 044 понравились пользователям.
Группа: Super Administrator
It doesn't wort in one case only - when you try to evaluate it numerically in a single line like:
P.S.: Will try to release new SMath Studio version as soon as possible.
Regards.
Radovan Omorjan 27.02.2012 15:25:00
#4 Опубликовано: 28.02.2012 05:18:42
scottg
scottg
Thanks for the help
#5 Опубликовано: 05.03.2012 05:47:22
Also in v.093 remains the problem reported by Scottg. The solution indicated by Radovan, it works properly.
Sergio
Davide Carpi 05.03.2012 05:53:00
#6 Опубликовано: 30.05.2012 16:04:55
Fixed in SMath Studio 0.94.
Regards.
Radovan Omorjan 30.05.2012 16:06:00, Davide Carpi 30.05.2012 16:11:00
