Transform formulas
Transform formulas - Сообщения
#1 Опубликовано: 05.02.2023 17:43:18
Marco
Marco
0 сообщений из 10 понравились пользователям.
Hello
I would like to convert formulas, as an example v=s/t what is s=?
and then only as formula s=v*t
#2 Опубликовано: 05.02.2023 18:12:05
SMath symbolic solver capability is limited.
These type of formulas can't be solved by numeric solvers.
You will need a plugin, either maple or maxima.
They can be installed via Tools>Plugins.
Maple is compact, easy to use, one click install.
Maxima is more capable but third party installation required.
Just use boolean equal sign for your formula.
Don't forget to change optimization to Symbolic via Right Click menu.
#3 Опубликовано: 05.02.2023 18:16:25
Marco
Marco
alright thanks I will try first maple then maxima.
the formula was only as example I would change the formula for the safety factor for bending on a shaft.
#4 Опубликовано: 05.02.2023 18:17:25
You are a new user, so remind this. Jean has his own agenda.
His intention will not be helping you, just read his replies and go on.
If you can't get what he is saying he is probably giving you wrong answer.
All new users are confused by his meaningless posts.
#5 Опубликовано: 05.02.2023 18:21:29
Marco
Marco
hahahaha nice so he is the Smath studio forum Troll/golum
but thanks for getting me to this point.
#6 Опубликовано: 05.02.2023 20:53:05
Marco
Marco
i try it and looks like its work thanks.
for obvious reasons i do not know yet if it is so correctly converted I will try it tomorrow with a whole calculation and then see if it is right.Have a nice evening
formel umstellen
( google search keywords ((hopefully it works out)) smath formulas transform formeln umstellen )
#7 Опубликовано: 06.02.2023 13:23:00
It should work fine.
If you can't get what you seek, you can post your file for further assistance.
Ask anytime for aid, there will be an experienced user willing to support.
SMath community is kind and helpful. Well, apart from Jean.
NDTM Amarasekera 06.02.2023 13:33:00
