Problem with Optimization
Problem with Optimization - Сообщения
#1 Опубликовано: 16.01.2012 07:28:25
Edward Ulle
Edward Ulle
21 сообщений из 182 понравились пользователям.
The following file will crash if Optimization is set to Symbolic with SMath 0.9. Just something for Andrey to play with in his spare time. :d
https://smath.com/wiki/GetFile.aspx?File=forum_attach%2fTheWizEd%2f4100422_New_Crane_Beam.zip
Ed
#2 Опубликовано: 17.01.2012 04:27:51
2 342 сообщений из 4 041 понравились пользователям.
Группа: Super Administrator
Thank you! Will fix it soon.
Regards.
#3 Опубликовано: 17.01.2012 04:52:40
Edward Ulle
Edward Ulle
Andrey,
Could you explain the purpose of the Symbolic and Numeric Optimization and when either is appropriate. If I turn on Numeric Optimization and hoover over an equation I see fractions with numbers with 10^15 or higher. I believe its to come up with a denominator which is the largest integer value. Why not just use the floating point value of the equation?
Ed
#4 Опубликовано: 23.01.2012 19:00:09
Fixed.
Regards.
Radovan Omorjan 23.01.2012 20:36:00
