[Nonlinear solver] Vectorize Operator and Symbolic Optimization in SS 6179
[Nonlinear solver] Vectorize Operator and Symbolic Optimization in SS 6179 - Сообщения
#1 Опубликовано: 03.02.2017 05:34:27
NDTM Amarasekera
NDTM Amarasekera
The attached image shows different results in symbolic optimization in using Vetorize Operator, and
consequently generates an error when using "FindRoot" function in the attached worksheet.
When Equations 1B & 2B are disabled and 1A & 2A enabled, "FindRoot" gives the result.
Vectorize error - Symbolic Optimization.sm (189,05 КиБ) скачан 1326 раз(а).
#2 Опубликовано: 03.02.2017 06:07:35
if you initialize the vector Q, then it works
Q:mat(el(Q,1),el(Q,2),el(Q,3),el(Q,4),4,1)
Davide Carpi 03.02.2017 07:26:00, NDTM Amarasekera 03.02.2017 11:20:00
#3 Опубликовано: 03.02.2017 06:42:52
NDTM Amarasekera
NDTM Amarasekera
Thank you! It works.
#4 Опубликовано: 03.02.2017 12:11:43
Your red vectorise is just a display, i.e: not an assignment.
Unlike the "red vectorise", the "blue vectorise" ASSIGNS the
vector required by FindRoots, thus immaterial wrt Symbolic/Numeric/NONE
The suggestion to initialise is not technical to me [just a comment].
It simply confuses matters. There is a long route to explore/clarify
the Smath Vectorise operator
