Overflow error in for loop
Overflow error in for loop - Сообщения
#1 Опубликовано: 30.08.2009 01:52:43
Greg Locock
Greg Locock
0 сообщений из 53 понравились пользователям.
Using the factorial for loop example
I ran the for loop example, eg with the counter set to 173
a:=1
for i:1,i<173,i:=i+1
a:=a*i
a=
which gives a remarkably small answer without an error message
This software has great potential by the way, thank you.
#2 Опубликовано: 30.08.2009 10:39:14
I think you are right. I also suppose it is a bug!
[LIVE width=457 height=408]http://smath.info/live/?file=604[/LIVE]
Try yourself, please
[MATH]173!=#[/MATH]
or
[MATH]173!—#[/MATH]
The error has been issued this time - overflow!.
#3 Опубликовано: 30.08.2009 11:02:56
Greg Locock
Greg Locock
Oh, sure I have no problem with the factorial function overflowing, what I didn't like was the absence of an error message in the little program. You have incidentally answered another puzzle, how to use the "for" keybutton. Cheers greg
#4 Опубликовано: 30.08.2009 11:16:21
A agree with you. Andrey will answer on this, for sure. Btw., I think he is rather busy at the moment. In a day or two a new release should be here.
You are welcome. Some things could be a problem at the beginning because there is no Help or Tutorial yet.
Btw., I hope you understood these two ways of "for" loop? The second one is obtained with "range" function. If not, let me know and I will give you a detailed explanation.
#5 Опубликовано: 30.08.2009 12:04:16
2 343 сообщений из 4 055 понравились пользователям.
Группа: Super Administrator
Fixed. Thank you.
#6 Опубликовано: 30.08.2009 12:46:27
Thank you
#7 Опубликовано: 30.08.2009 18:19:10
Finally, in order to avoid possible errors in the calculations below I've decided to forbid using variable, that caused an error.
Release will be available tomorrow in the midnight (01.09.2009).
