Stop common units from switching after equal sign
Stop common units from switching after equal sign - Сообщения
#1 Опубликовано: 06.11.2024 03:42:45
DM
DM
0 сообщений из 12 понравились пользователям.
Hello!
I have an equation that I am inputting mm^4 for moment of inertia, and the output of the equation is giving me m^4. How can I get it to display in mm^4 as that is the way the values are represented in textbooks?
#2 Опубликовано: 06.11.2024 04:03:31
⚜ Kenny Lemens, P.E. ᵂᴵ
85 сообщений из 180 понравились пользователям.
Greetings;
SMath does not support "preferred" units, but the answer to your question is to click on your equation; after the '=' you will notice a black square; this black square is a placeholder where you can manually type your units, so:
200 mm = 0.2 m▮ -- > can be (typing 'mm into the ▮ placeholder):
200 mm = 200 mm
May this be of Good Help;
#3 Опубликовано: 06.11.2024 10:33:43
DM
DM
Greetings;
200 mm = 200 mm
I have tried adding the mm after the equals sign, but then it shows as m^3 mm, instead of mm4. Do I need to type mm^4?
#4 Опубликовано: 06.11.2024 22:23:32
Greetings;
Correct, type into the placeholder the unit you wish to see it report in, so for you mm to the power of 4. SMath will attempt to report the result in those terms, but will make up the difference if the units don't 'match' (as was in your case)
'mm^4
#5 Опубликовано: 04.12.2024 07:43:33
26 сообщений из 155 понравились пользователям.
If you do some searching on the forum, you will find some information regarding modifying the units setting file so that you can get the units you want. This is not an official feature, so do it at your own risk.
#6 Опубликовано: 13.04.2026 06:07:20
Norrah_Casper
Norrah_Casper
It can be pretty annoying when the units flip to something unexpected after the equal sign. Usually, you can click on the unit placeholder (the small black rectangle at the end of the result) and manually type in the unit you want to keep. SMath should remember that preference for that specific calculation.
Another trick is to define your preferred unit at the top of the worksheet if you're consistently seeing the same switch. It’s a bit of a manual workaround, but it definitely keeps the document looking cleaner!
