how to change result units to normal
how to change result units to normal - Сообщения
#1 Опубликовано: 27.01.2024 22:44:39
meka1240
meka1240
Hello
as in the title, how to change the result units to normal, previously I had normal results in integers, now the results have changed, for example (21761.554+5474.6904*i) these are electrical calculations
#2 Опубликовано: 29.01.2024 22:01:45
⚜ Kenny Lemens, P.E. ᵂᴵ
Greetings,
I rarely work with complex numbers, but it is work noting that SMath does have two functions:
  • Re() = "Returns the real part of a complex number."
  • Im() = "Returns the imaginary part of a complex number."
Hopefully you can use these functions to generate the normal value you seek
May this be of Good Help;
