Equation in tooltip missing brackets
Equation in tooltip missing brackets - Сообщения
#1 Опубликовано: 22.08.2016 08:32:32
Jaan Praks
Jaan Praks
1 сообщений из 9 понравились пользователям.
When the cursor is over an equation, it shows the long version of it. However, the tooltip equation (with the yellow background) misses often brackets, which makes the equation wrong. See attached:tooltipproblem.png
Andrey Ivashov 22.08.2016 12:39:00
#2 Опубликовано: 22.08.2016 08:36:11
Mike Kaganski
Mike Kaganski
http://en.smath.info/forum/yaf_postst7437_Tooltip-doesn-t-show-brackets-properly.aspx
С уважением, Михаил Каганский
#3 Опубликовано: 22.08.2016 12:38:44
2 337 сообщений из 4 035 понравились пользователям.
Группа: Super Administrator
Thank you! Will fix it asap.
#4 Опубликовано: 22.08.2016 12:47:19
Fixed. Will not be an issue anymore in the next SMath Studio release.
frapuano 22.08.2016 15:15:00, Jaan Praks 22.08.2016 16:03:00, Davide Carpi 23.08.2016 04:24:00
#5 Опубликовано: 25.08.2016 05:03:45
NDTM Amarasekera
NDTM Amarasekera
Tool tips problem.
Tooltip.pngTool tips problem
#6 Опубликовано: 25.08.2016 16:55:03
Fixed: http://en.smath.info/forum/yaf_postst7719_SMath-Studio-0-98-6081--25-August-2016.aspx
#7 Опубликовано: 25.08.2016 16:56:20
NDTM Amarasekera
NDTM Amarasekera
Thank you Andrey!
It works fine
