UPDATED: Stable: SMath Studio 0.99.6671 (07 April 2018)
UPDATED: Stable: SMath Studio 0.99.6671 (07 April 2018) - Сообщения
#21 Опубликовано: 24.05.2018 16:49:57
Mo
Mo
0 сообщений из 34 понравились пользователям.
Hi, for some reason after I installed the new version when I open previous files the content does not fit anymore within the page.
I tried uninstall SMath and reinstall older versions but still have the same issue.
Can anyone help? this will be lots of work to re-fit everything back within the page.
The first figure is for the messed format, the second one is for the original format.
Thanks.
#22 Опубликовано: 24.05.2018 16:59:50
Arie
Arie
If I recall, this latest update fixed some issues with regards to display scaling, which is probably what has caused your format issues by updating. Unfortunately, I believe your options are to either stay with the the older version, or refit everything manually.
#23 Опубликовано: 24.05.2018 21:02:16
This option [update] is not so simple. My other laptop 3 feet at right Win 10
was updated 6671 including the infinitely difficult inclusion Maxima.
Open two work sheets from 6179 USB ... all red. Didn't even try to doctor.
Since more recent than 6179, your logrange is the first one that din't upload/download.
Damned hard to explain. Davide special works fine ...
Thanks: alyles, Davide ... stay good !
#24 Опубликовано: 03.09.2018 08:46:27
1 346 сообщений из 2 259 понравились пользователям.
Andrey or Davide, could you please update the core documentation? Thanks in advance.
#25 Опубликовано: 03.09.2018 09:12:06
1 440 сообщений из 2 927 понравились пользователям.
Andrey is baking a new software update with several changes in the core, the documentation will be updated after the release.
