Weird Unit Conversion kg <> ton
Weird Unit Conversion kg <> ton - Сообщения
#1 Опубликовано: 14.05.2018 05:27:41
usamakhan
usamakhan
7 сообщений из 97 понравились пользователям.
The question is simply clear ...its should be a matter of removing or adding x3 zeros
aMIR.sm (10,5 КиБ) скачан 1154 раз(а).
#2 Опубликовано: 14.05.2018 05:36:20
Simple as the question
#3 Опубликовано: 14.05.2018 06:00:37
usamakhan
usamakhan
Thanks ...but can you tell me what is the wrong in this kg <> ton ...it should just reduce the power to 10 from 8 to 3 without changing the values
#4 Опубликовано: 14.05.2018 06:04:53
I missed it...
You have to use 't (metric ton) because 'ton here is the US "short ton"
#5 Опубликовано: 14.05.2018 06:10:11
usamakhan
usamakhan
I think its the problem ...I was expecting MetricTons
Problem solved
