Speed up a program
Speed up a program - Сообщения
#1 Опубликовано: 22.12.2023 01:06:26
Valery Ochkov
Valery Ochkov
67 сообщений из 708 понравились пользователям.
How can you in an attachment?
PreClean.sm (63,67 КиБ) скачан 1524 раз(а).
#2 Опубликовано: 22.12.2023 07:17:27
599 сообщений из 1 380 понравились пользователям.
Some numbers can not be calculated for D().
Iteration doesn't concluded because "≉".
I have replaced it with an epsilon.
To plot it is better you eliminate units.
X-Y plot can but 2D plot cannot plot with units.
I had to put plot under an eval().
PreClean_fast.sm (63,85 КиБ) скачан 1481 раз(а).
Valery Ochkov 22.12.2023 10:09:00
#3 Опубликовано: 22.12.2023 10:06:37
Hi. Just use the recent Davide solution: Ctrl-A for select all, right mouse click and choose numeric optimization. The calculus is done in less than one second.
#4 Опубликовано: 22.12.2023 10:20:04
Valery Ochkov
Valery Ochkov
#5 Опубликовано: 22.12.2023 10:22:07
I did this first but doesn't work for my setup.
I don't know why, maybe because I use linux.
