Equation number in a
Equation number in a - Сообщения
#1 Опубликовано: 04.11.2017 17:04:03
Paulius
Paulius
0 сообщений из 11 понравились пользователям.
Then writing master thesis I need numbering equation there's a methods to put number on equation, or simple I need put the text near formulas. Example:
3+4=8 (101)
2+3=5 (102)
#2 Опубликовано: 05.11.2017 06:43:35
Hello [userlink]Paulius[/userlink],
You can start writing a text region simply by typing the double quotes character (") anywhere in the canvas
You can even use the description area (right click on the math region -> show description) and move it to the side you want dragging his left edge.
#3 Опубликовано: 05.11.2017 07:17:33
Equation [1], [2] are one line, they lineup nicely.
For equation of num/den style: use a construction line
that you will delete after construction.
#4 Опубликовано: 05.11.2017 07:46:56
You can highlight a graph or any math region simply:
1. capture the graph frame using "WinGrab" [freeware]
2. crop the Wingrab selected region
3. copy/paste in IrfanView, inverse colors
Inst_Mach Number Pitot [PUBLISH].sm (30,78 КиБ) скачан 1055 раз(а).
