[SMath Viewer PRO] SV vs third-party plug-ins (Regions)
[SMath Viewer PRO] SV vs third-party plug-ins (Regions) - Commercial Smath Viewer does not display the graphical X -Y Plot - Сообщения
#1 Опубликовано: 28.07.2016 13:48:55
CBG
CBG
Carlos
Human eye.sm (6,4 КиБ) скачан 1367 раз(а).
Human eye_Comm_and_Free.zip (1,07 МиБ) скачан 429 раз(а).
#2 Опубликовано: 29.07.2016 09:17:27
Hello Carlos,
I haven't understood what the Viewer was designed for. That's personal only.
Maybe for the facility to add comments ? In this typical image, I can add as
much as desired to a accommodate each particular application.
I understand your point: Commercial Viewer does NOT capture the plot.
#3 Опубликовано: 29.07.2016 13:05:27
CBG
CBG
Hi Jean :
Thank you for your comments.
I explain how I see the use of Smath Viewer.
A program was developed to calculate or design something , in order that almost anyone can use it with minimal knowledge.
The person using it , simply by changing the input data , this can calculate or design element in smaller or larger size .
The person does not see the formulas or source code . Then Smath Viewer is ideal to be used by almost anyone .
In my case, I am trying to develop a program to calculate and design Wastewater treatment Activated Sludge fine bubbles Plants .
The graphical X -Y plot , use it to graphically display the distribution of air diffusers .
Some screenshots
Small Plant (two diffusers).
A slightly larger plant (60 and 48 diffusers)
frapuano 29.07.2016 13:30:00, Ernesto 29.07.2016 15:30:00, Davide Carpi 30.07.2016 05:04:00, Andrey Ivashov 05.08.2016 11:27:00
#4 Опубликовано: 29.07.2016 20:26:04
Thanks Carlos. A great tool the Viewer !
#5 Опубликовано: 05.08.2016 11:29:42
Группа: Super Administrator
This is because SMath Viewer Pro doesn't support third-party plug-ins (because of technical challenges). I'm working on it...
#6 Опубликовано: 05.08.2016 15:34:52
CBG
CBG
Andrey
Thanks for your reply-
But I have curious to know , because the free version of Smath Viewer does support the Plugin X -Y Plot, and PRO version does not , if it is assumed that the PRO version has more features .
Carlos
#7 Опубликовано: 05.08.2016 18:11:22
You are right. But the reason of why SMath Viewer Pro costs nothing is that it is not actually ready yet.
It will support third-party plug-ins when I will implement it.
#8 Опубликовано: 05.08.2016 20:32:53
CBG
CBG
Thank you very much.
Best Regards.
Carlos
