"Not defined" Error - Why?
"Not defined" Error - Why? - Сообщения
#1 Опубликовано: 07.07.2021 03:17:13
Topaz
Topaz
Hello all,
please forgive me if the question is maybe ridiculous.
I want to use the symbolic solver with the maxima plugin, but when I write the equation I get the error that the variable a is not defined.This is correct, because I want to solve for this variable.
Therefore the question which mistake I make here?
#2 Опубликовано: 07.07.2021 03:50:03
Andrey
Andrey
1 сообщений из 44 понравились пользователям.
Hello all,
you must force-define the symbolic analysis through a pop-up menu
Davide Carpi 08.07.2021 07:38:00
#3 Опубликовано: 07.07.2021 09:52:06
maple is native in Smath for lot more with less trouble.
Contour Solve Isocurve DESCARTES.sm (41,25 КиБ) скачан 1208 раз(а).
#4 Опубликовано: 07.07.2021 21:06:01
599 сообщений из 1 380 понравились пользователям.
As andrbig77 said, you have to set optimization to symbolic.
Maxima plugin is powerful, but requires manual installation.
For information, involving these type of symbolic calculations;
Maple plugin could do the same with much less effort.
Just click and install from plugins menu, that's all.
