Modulus of a vector
Modulus of a vector - Сообщения
#1 Опубликовано: 19.04.2021 03:25:40
JJJ
JJJ
0 сообщений из 13 понравились пользователям.
I want to calculate the magnitud or modulus of a vector. In mathcad I think is something like the name of the vector between four stripes.Thank you.
#2 Опубликовано: 19.04.2021 05:25:50
1 441 сообщений из 2 932 понравились пользователям.
The magnitude of a vector can be calculated using norme()
#3 Опубликовано: 19.04.2021 05:41:06
JJJ
JJJ
Hello Davide, thanks for your response. Do you have an example? I try to do that but I can´t, I don't know what I am doing bad. Thanks.
#4 Опубликовано: 19.04.2021 06:34:15
#5 Опубликовано: 19.04.2021 09:19:53
I want to calculate the magnitude or modulus of a vector.
#6 Опубликовано: 19.04.2021 09:34:05
#7 Опубликовано: 19.04.2021 22:34:23
JJJ
JJJ
Hello, thank you, I restarted my computer and now is ok.
As you know, sometimes the software is used with educational purposes, and if you define commands (such as norme and something like this) is a quite difficult to students. Is there a possibility, for example as is done in Mathcad, to define the norme command graphically (with two strips in both sides of the name of the vector)?.
Thank you very much.
#8 Опубликовано: 20.04.2021 06:57:57
Currently you can accomplish this by overriding the built-in abs function (as shown by Razonar here), and using it twice. Not straightforward for productivity but might be enough for documentation purposes.
#9 Опубликовано: 20.04.2021 09:06:33
JJJ
JJJ
Hello Davide,
Thank you very much, but I think that it would be a good idea to program and that it will be inside the software in future versions if possible, because it is a very useful tool.
JJJ
#10 Опубликовано: 20.04.2021 09:13:36
Thanks Davide ... can you show an example that my post 5, 6 fail ?
So that I will update as proven.
#11 Опубликовано: 21.04.2021 06:31:19
Here you have.
magnitude.sm (11,13 КиБ) скачан 966 раз(а).
churichuro 21.04.2021 14:24:00
#12 Опубликовано: 21.04.2021 09:09:40
Here you have.
... sanity algo style.
Thanks Davide ... Jean.
