Problem with pictures - Linux
Problem with pictures - Linux - Сообщения
#1 Опубликовано: 03.10.2009 08:13:21
Remmen
Remmen
First, a great piece of software you've created!
However, I've got a problem inserting pictures in the Linux version (Mint 7 based on Ubuntu 9.04, 64 bit).
I've got a .png-file from Geogebra. When I try to drag and drop it into SMath I get the following error message:
Exception of type 'System.Text.DecoderFallbackException' was thrown.
When I try to copy and paste the picture i get this error message:
CriticalError
Object reference not set to an instance of an object
ControlCanNotBeDisplayed
Is there anything I can do about it or is it a general error?
Lars
#2 Опубликовано: 04.10.2009 21:10:41
2 337 сообщений из 4 035 понравились пользователям.
Группа: Super Administrator
Hello, Lars.
SMath Studio cannot handle drag and drop actions with images yet - only .sm and .xmcd files. Will implement.
Copy/Paste should work. Will check and fix it later.
You can also try to insert bmp image throw the "Insert" >> "Image" >> "From File" dialog while I'll fix other stuff.
Best regards, Andrey Ivashov.
