1 страниц (7 вхождений)
Tutorial - Creating Plugins - Сообщения
Are there plans for releasing of a "Symbolic expression evaluations" tutorial?
WroteAre there plans for releasing of a "Symbolic expression evaluations" tutorial?
IMHO too much like re-writing Bible.
1000's demo ... show your expression/formula.
WroteWroteAre there plans for releasing of a "Symbolic expression evaluations" tutorial?
I would like to write the nabla vectorial operator, in order to get gradient, divergent and rotational operators.
Maybe... I have some technical issues ATM, so I can't really plan it for the near future.
If you want to give a try to low-level evaluation, about the math you might start from the gradient already coded here. To dress it, you can see this (that if you have the plugin installed should already works if you create your own 1 or 2 arguments function in a worksheet and you call it grad)
WroteI would like to write the nabla vectorial operator
Borrow from here.
Maths Grad_Div_Curl_Jacob.sm (41,3 КиБ) скачан 1256 раз(а).
sergio 28.04.2019 13:48:00
Hi. Maybe you found useful this post: https://en.smath.com/forum/yaf_postst16005_Grad--Div-and-Curl-in-a-curvilinear-coordinate-system.aspx
WroteWroteI would like to write the nabla vectorial operator
Borrow from here.
Thanks a lot!
