Stable: SMath Studio 0.89 (23 July 2010) - Messaggi
Absolutely free mathematical program with "paper"-like interface and numerous computing features (now with integrated mathematical reference book).
CitazioneControls:
With consecutive pushing of this button you can choose: "1", delimiter of the number ",", "square root - sqrt", "n-th root - nthroot", "integral - int", "function to find roots of equations - solve". To lock any variant just stop pushing this button 1 second.-
With consecutive pushing of this button you can choose: "number related to the button", "symbols related to this button". To lock any variant just stop pushing this button 1 second.
With consecutive pushing of this button you can choose: "plus operator", "minus operator", "multiplication operator", "division operator", "exponentiation operator", "plus/minus operator", "factorial", "vector multiplication operator". Also with this pushed button you can highlight the part of equation by using Left/Right buttons.
By "clicking" on this button program will numerically calculate equation (this means "="); by pushing button more than 0,4 sec. program will symbolically calculate equation (this means "->"). Also, if the cursor located on the right of the not defined variable or not defined function this button will create a definition operator (this means ":=" ).
Removing last character (Backspace). In the mathematical reference book this button means "Back".
- Added support for subscript in variables, units and functions;
- Functional programming feature implemented;
- Keystrokes added to allow text regions formatting: Ctrl+B (bold switcher), Ctrl+I (italic switcher) and Ctrl+U (underlined switcher);
- Ctrl+Insert and Shift+Insert keystrokes implemented;
- Right button after the left part of evaluated expression now brings cursor to the Units placeholder;
- Added ability to modify name of the created functions without removing it;
- Added ability to automatically highlight repeated variables inside the Math region;
- Multiple-rename functionality implemented using F8 keyboard button;
- SMath Studio Live link added on the main menu under "Help" section;
- Added ability to remove Arguments Separators of the functions using Backspace keyboard button;
- ksi, ksf, rpm and radpm units implemented;
- Réaumur scale Unit name changed to "°Re" (from "°R");
- Insert Unit Dialog keystroke changed to Ctrl+W;
- Calculation menu actions improved;
- Accuracy of calculations with "e" and "pi" constants improved;
- Accuracy of calculations with a numeric sin(..), cos(..), tan(..) and cot(..) functions improved;
- XMCD file type support plugin updated in order to support strings inside math regions and variables/functions with literal subscript;
- Added ability to paste operands into the other operands within the math Control;
- Dynamic Assistance feature improved to show user-defined variables before built-in units with the same names;
- Dynamic Assistance items list now hides on error in the math region;
- Values of built-in variables/parameters are included to the Dynamic Assistance list;
- Fixed issue when Dynamic Assistance items list was not shown or its location was wrong;
- Desktop: Restrictions to insert matrix more then 100*100 using the Insert Matrix dialog modified to 10000*10000;
- Desktop: Quick search of the non-linear units using Insert Unit dialog fixed - now search is not case-sensitive;
- Example file Translator info now shown into the Examples Dialog;
- New example included: Gravitation Acceleration;
- Desktop: Roman Numerals example file included to the binaries archive for Mono;
- Desktop: Font sizes toolbar drop-down list enabled for Linux version;
- Desktop: Fixed issue with tall toolbar when latest versions of Mono used;
- Behavior of numeric round(..) function changed to "round away from 0";
- Behavior of trunc(..) function changed to "trunc closer to 0";
- Fixed critical error of the Math region occurs on using "#" char in variables or functions names;
- Error occurs when user uses infinity symbol as a part of variable/unit/function name fixed;
- Underscore ("_") char is now visible in variables names;
- Underscore ("_") symbol now can be used inside math regions;
- Boolean operators priorities corrected;
- importData(..) function improved to work with any of separators specified in options of the program;
- Fixed issue with only partially shown grid of the Plot Controls;
- Fixed issue when it was not possible to change background color of the Plot and Area Controls;
- Fixed wrong Copy/Paste text data issues;
- Fixed error when DELETE button parsed twice at once;
- Fixed issues with wrong graphical representation of math expression (invisible brackets issue);
- Fixed issue with not working trigonometric functions when user specifies Degrees as angles type in options;
- Fixed simplification error: 0.75/abs(0.00003);
- Fixed symbolic error with ln(..) and lg(..) functions: lg(1/{2*a}) -> lg(2*a);
- Simplification error fixed: sqrt((1-a)^2)->1-a;
- Fixed issue when numeric inverse trigonometric functions returns result with superfluous imaginary part;
- Error occurs on numeric "inf^i" calculation fixed;
- Function abs(..) improved in the numeric library;
- Numeric calculation error of the sinh(..) function fixed;
- Numeric calculation of functions acosh(..) and atanh(..) fixed;
- Couple of errors with numeric infinities comparison fixed;
- Critical error fixed, occurred when two or more users work with single on-page Control through the Teamwork Session;
- Critical error fixed appears when loops are used in the right part of math expression;
- Fixed critical error on opening file, created with a text control language, which is not installed in the target machine;
- Language interface translations added: [SRP] Српски (Serbian Cyrillic), [RON] Română (Romanian), [BEL] Беларуская (Belarusian), [NOR] Norsk (Norwegian);
- Language files updated;
- Refactoring.
- Handheld:
Framework: .NET Compact Framework 2.0 cab (5,33МБ), zip (1,99МБ)
Compatibility: Pocket PC 2002, WM 2003, WM 2003 SE, WM 5, WM 6, WM 6.1, WM 6.5, full VGA support, all PPC's, Comunicators and smartphones. - Desktop (Windows):
Framework: .NET Framework 2.0 - Desktop (Linux):
Desktop и Handheld (27 languages):
- Handheld (PPC, Communicator, Smartphone):
SMathStudioHandheld.0_89.Setup.cab (Date: 23.07.2010. File size: 2.37MB) - * To install from the device
SMathStudioHandheld.0_89.Setup.cab.zip (Date: 23.07.2010. File size: 560.83KB) - * To install from the device (archive with CAB inside)
SMathStudioHandheld.0_89.Setup.exe (Date: 23.07.2010. File size: 567.92KB) - To install from the PC - Desktop Windows (desktop computer with Windows OS):
SMathStudioDesktop.0_89.Setup.msi (Date: 23.07.2010. File size: 1.34MB)
SMathStudioDesktop.0_89.Portable.exe (Date: 23.07.2010. File size: 17.29MB) - .Net Framework 2.0 doesn't required - Desktop Linux (desktop computer with Linux OS):
SMathStudioDesktop.0_89.Mono.tar.gz (Date: 23.07.2010. File size: 652.91KB) - last version of Mono distributive required!
* For installation of the program from PPC it is necessary to transfer a file on Your handheld computer (for example, with MS ActiveSync) and start it there with Your file manager.
** For installation of the program from PC it is necessary to install MS ActiveSync first.
SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Article.Eng.pdf (Date: 23.09.2009. File size: 828.96KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.IOFiles.Article.Eng.pdf (Date: 27.09.2009. File size: 453.24KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.NumericFunctions.Article.Eng.pdf (Date: 18.10.2009. File size: 622.45KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Programming.Article.Eng.pdf (Date: 18.10.2009. File size: 411.74KB) - to open in Adobe Acrobat Reader
SMath Studio icons (
SMathStudio.Icons.zip (Date: 12.04.2010. Size: 63.74KB)
-maxx
"Softpedia guarantees that Portable SMath Studio 0.89 Build 3856 is 100% Clean, which means it does not contain any form of malware, including but not limited to: spyware, viruses, trojans and backdoors."
(details)
Regards.
Felipe.
I will love to work with it in parallel with my Mathcad in order to test it.
Any planes for an Android version? I don't think you have any compatitors there...
my question is, wether there was some progress in development of free? import tools to read in MATHCAD mcd files;
would be happy when someone could write a short resume, how-to-do, for the actual state,
much thanks
was trying to get the linux version, but cant get to download mono, just filling in forms
WroteSmathPrimer.pdf is in-part a compilation of existing documents (edited as I saw fit) plus some of my own work. I tried to cover all the problem I had as I started to learn SMath. It is primarily for people who are new to SMath and would like some notes all in one place.
Document added to the main download page:
WroteSMath Studio tutorial by Bernard Liengme.
Many thank to Bernard Liengme for his great work!
Many thanks to Marijan Dizdar for the Tutorial for Beginners in Serbian
SMath priručnik
