1 pagine (3 elementi)
Default filetypes - Messaggi
Andre et all-
Would you consider adding an option box for the default file save type? I would like to set SMath to default to .smz instead of .sm. I realize that I am probably in the minority but want to throw it out there.
Thanks
sinneD
Thanks
sinneD
WroteWould you consider adding an option box for the default file save type?
Once you have constructed the Smath document, including miscellaneous stuff "files".
you can save *.sm or *.smz
Then isn't true that at re-opening *.smz you recover the file stuff as well ?
WroteOnce you have constructed the Smath document, including miscellaneous stuff "files".
... on the other hand: not every/any Smath piece can be saved to file ...
i.e: the collector { can't be saved to file,
saved it otherwise vector style.
